Guys, I've just put 18" rims on the AU, I'm happy with the ride hieght at the front but am a bit unsure about the rear. Is it an option to fit say sports rider springs on the rear to drop it about 20mm or is this the wrong approach?? Please remember I'm a country bumpkin and cant rub my ass on the road as i drive. Cheers....
BSR
Kings 'Low' (not superlow) will give you a drop of about 15-20mm without problem.
Did the same with mine and it makes a huge difference....;)
I was told the AU XR springs are the equivalent ride height to the Kings 'low', and to get any visible reduction in height, the XR's require 'super low'.
Kings springs are about $495 fitted for all 4 corners.
Rear springs shouldn't cost more than $130pr, you can put them in yourself, they are easy peasy. If you haven't got the tools or the inclination it should only cost $50 labour, any more and they're ripping you.
