1 - 11 of 11 Posts
Toni
went to replace my plugs and couldn't get the last one out (no.6? closest to firewall)? ended up piling crc down the plug and undoing then doing up again until it finally broke free. totally covered in rust about 5 mls up from the bottom of the plug and now i have a slightly cross threaded spark plug chamber. (new plug went in ok though). pulled out plug two week later and already rust starting to build up again and plug was already rounding off at point... what could this possibly be??? car runs beaut usually.. doesn't miss or fart around .. it's on lpg whether that makes a difference?
thanks again
Toni
pretty sure it isn't that ausieblue.. as it is the whole thread rusted out.. not the actual electrode etc....?? relief about the head gasket though.. :) even though that is probably due to happen soon with the mileage.
Toni
just had a big read on MMT and it wouldn't apply if i'm using LPG would it?? when i went to get a new plug the parts guy said i've been running the wrong plugs and gave me the right ones for lpg.. maybe that was the problem?? will check them again in a fortnight. thanks heaps guys
G'day,
aluminium head....hard to generate rust between it and the plug.....
Makes me ponder if the thread hasn't previously been damaged, and a helicoil has been used to repair it....most likely done in car.
Jas
Toni
that's clever thinking jas.thanks for that. would i not be able to see the helicoil if there is one? I'll have to get that thread redone.. as it is going to be an ongoing problem by the looks. Had a squizz at the manual and it advised putting anticorrosion grease on the ends of the plugs when changing.. maybe it is a problem with the EAs? if it weren't for the lpg on this, i'd be getting an update.... a few things are starting to pack up.. but fuel prices are too awful here at the moment..
G'day,
it was merely an idea...steel on steel creates rust.
Yes you will be able to tell if it has had a helicoil....simply compare the plug hole to another...look for differences...you should be able to see the helicoil
Jas
old B - new B
on my old XF ute i had a rusty number 6 plug and it was caused by the alloy head was eaten out between the water jacket and the cylinder, making it leak past the head gasket.
had to get the head welded up , fixed the problem and cost about $250 with a valve grind .
it would miss a bit when it was cold then be fine,
Australian ED Fairmont Member
Jas, helicoils are made from stainless steel and therefore do not rust. I also have the rust plug problem on my 2 ED's due to weeping head gaskets.
1 - 11 of 11 Posts
