Here's some parts i am selling off to fund my new engine
KUNTZ AND COMPANY LONG ROD 306 SHORT BLOCK..THE SHORT BLOCK HAS A 3" STEEL CRANK, SCAT 5.400 H-BEAM RODS. CUSTOM ROSS 11.3 LIGHT WEIGHT RACE PISTONS 447G.THE RINGS ARE C&A WITH RACE BEARINGS.THE BLOCK IS A EARLY 302 THAT HAS BEEN BORED AND HONED WITH PLATES,SQUARE DECKED AND LINE HONED.THE SHORT BLOCK HAS BEEN BALANCE AND BLUEPRINTED.THE SHORT BLOCK IS IN VERY GOOD CONDITION WITH ONLY 20-25 PASSES WITH NO STREET MILES AND IT HAS NEVER BEEN SPRAYED.THIS SHORT BLOCK HAD BEEN 10'S N/A.THE ONLY REASON I AM SELLING IS I AM . I HAVE OVER $3000 IN THE SHORT BLOCK, SELL FOR $2000obo
Used SMALL BLOCK FORD COMP CAMS ROLLER TIP ROCKER ARMS. 1.6 RATIO FOR USE WITH GUIDE PLATES $100
New FABRICATED aluminum small block ford valve covers.These are made from .090 3003- h14 aluminum and 100%tig welded.Valve covers come with all mounting hardware and will fit all small block ford 289,302,351 $180 bb,fe and 351c $250
SRP 351W Pistons Flat-Top .part number 138730 .new $450
Used Jesel J2K Series 1.8 Roller Rockers and Stands for a Ford Yates Style Aluminum Heads $800
Used Romac billet timing chain$45
New Crane Hydraulic Roller Cams Custom Grind.Same as Ford 6250-B303 Except Lobe Center is 116.$180
New Trick Flow Twisted Wedge Cylinder Heads $1500
New Canfield sb ford cnc ported 18* 230cc race heads.The are are bare ready to go.they are good for over700hp. the heads were almost $2000 unported sell $2500
probe 1.6 shaft roller rockers.the guy i brought them from said they fit canfield and tfs hi-port.the only reason i am selling wont work on my new heads.didnt have a chance to use them.$650
i am in the u.s i will ship parts
email me at [email protected]
