hello guys i need some info on how to seam weld as i fought my rhd guard on my escort was in good nick but i found out its very very flexiable and the bottom part is bent to bad to be fixed. iam just wonderin if i drill all the seams out do i use a drill bit but do i drill right through or just enuff for the seam weld to become loose. and with a seam welder how does it work ie is it just a pole that i push against the lip to be welded or is there more to it.
cheers
cheers
