1 - 17 of 17 Posts
Go Nuts in Your Falcon
Hey,
about 2 years ago i was mucking around with the trip computer on my brothers EL2 Fairmonth Ghia and I came across a secret stop watch. I searched the owners manual and there was no mention of it. If you wanna know more, reply here. I will be willing to tell you how to do it if you don' t know already.
Paul
Here it is:
Bring the computer to a particular search function, any will do, ie distance left with fuel. Keep the reset button down for 10 seconds and a stop watch will come up. once in there, to start it, you press reset, to stop i think you do the same thing. to reset you hold o.speed and reset together, and to get out, just press search. if that isn't exactly right, just trial and error to find the functions
I hope it works for you
This is a genuine finding, so plz do try it.
I hope you get it to work, you can time your quarter miles with it.
Paul
Yeah very very true.
I am just wondering why the Trip computer has this function, but there is no mention of it in the manual. I was so proud when i found it.
Well, hope it brings everyone as much happiness as it brought me. Hahahaha.
Out
The Third Power
yeah we have found some of that stuff on the ls1s,
mode up arrow on start gives you
digital taco and speedo, digital temp sensor, battery voltage etc
The Third Power
looking at the service info on a VT Series 1 it seems to have the same functionality so I guess it should
Pursuit Reincarnation Dog
Correct - my VS GTS-R had many of these features too.
Chromed Member
EF EL XH tricks....
I think its something like this
Turn ign off
press odo reset 3 times quickly and hold reset buttton as you turn ignition on
by pushing button again should cycle between fuel consumption, l/100k, votages etc.
Turn key back off to go back to noraml
give it a go....
:nuts: :D
T5 Expert Operator
Guys i've retro fitted a futura clock in my car. Wonder if there any secrets in that clock. :nuts: :nuts:
Maybe an electronic 180km+ override mode :p :p :p
Australian XR6 Member
The stopwatch function may not be mentioned in the user manual, but it is documented in Volume 1 of the workshop manual ;)
I hope this attachment works :rolleyes:
Al.
Old Car:BA XR6 New: 97 EL
Re: EF EL XH tricks....
Turn ign off
give it a go....
:nuts: :D
Cool does this work on any EF/EL ?
Any Tips and Tricks for AUII ?
Shh i'm huntin more power
Turn ign off
give it a go....
:nuts: :D
Botch,
couldn't get it to work my EL....
Chromed Member
its been a while since ive done this, so ill try again soon Should work on EF EL NF NL XH . im not 100% sure of the on off sequence or number of presses of the odometer button.:(
1 - 17 of 17 Posts
