1 - 7 of 7 Posts
So my 96 probe gt 2.5 has been idling EXTREMELY high like 4000 rpms. I had a iac code and replaced that still did it replaced TPS still does it. But when I was setting the TPS the fan way, it never turned off. Anybody have info?
Did you try cleaning the throttle body? If you tried in place with just a spray, it probably didn't do much. That's a fairly high idle even for a dirty throttle body.
Yeah I took it apart and cleaned it before I replace the TPS and the iac.
After cleaning and replacing the iac valve is the throttle body spindle / butterfly closing o.k and not sticking ? Along shot but try disconnecting the MAF
Discussion Starter · #5 ·
Yeah I tried that when I was diaging it but nothing happened, I was told it could be an intake leak but I could find one and that's a pretty high idle for an intake leak isn't it?
I'd say it was high, but not necessarily impossible under the right conditions. It sounds like they throttle blade isn't closing fully. See if there's a gap between the blade or the seat on both sides.
Discussion Starter · #7 ·
Alright I'll check it again.
1 - 7 of 7 Posts
