1 - 14 of 14 Posts
Rip Up The Track Join OFR
I want to install a shift light in my BA XR8 only a light, I don’t want some big assed tacho. I think they start from around $200, any one know are they hard to install or should I get a pro to do it. Or can you recommend a brand or an installer
Maybe I should ask Herrod he might have something.
Any input would be greatly appreciated
thx..
:edit: need to find out if the BA has a tacho output on the diagnostic connecter like previous models.:edit:
try contacting 9psi eb, he has access to user definable RPM switches
thx for that TaraHymen I send him a pm...
Had a look at your cortina i had 2 a tc and a te long time ago great cars with a 6cyl donk in them do you think your 9 inch is taking a lot of your torque out of your engine with only running a 6 cyl. ??
yeah it probably is but it's hardly noticable. i scored a cheap cortina wreck with the falcon brake upgrade done and that came with it. i dont neccessarily need the 9inch but i'm more than pleased to have 4 wheels discs, a falcon stud pattern and a really tight lsd.
it did however make my steering alot heavier and it understeers due to the lsd - but i'll manage :)
Auto meter make one for around $230 and Spitfire make a copy for around $140.
I have just ordered a Spitfire one.
thx for the info SVO XR6, vbmenu_register("postmenu_606886", true); i found a gismo one that has a dual shift light ($199) and another one that has a daul shift light with recall ($329) but after doing alot of tacho watcing in automatic perfomance mode it changes at 5750rpm witch is perfect i couldn,t change the shift that good so i am not going to bother with the light or manual shifting.
thx..
Team Galaxy: Mad Bastard
I've seen a couple of the GISMO ones and they look really neat...not sure if I'd put one in my beast though (also becoz it's an auto)...
hi mal, i have an auto also but we can use a manual perfomance mode on the auto thats in the XR8 and the FPV cars. it wont change gear until you change it sits on rev limiter...
thx
Can't wait for Winton...
Someone, I can't remember who, did a really nice integrated custom unit a couple of months ago on a GT/P. Might have been in the FPV forum.
thx
Oh...Do you mean the SSS? Sequential Sports Shift?
Blood Orange Pursuit
Becareful with the shift lights on the BA, i bought one of those little sequential shift lights with the coloured LEDs, great little bit of gear.
Anyway the Pursuit was going in for a service so i asked the ford Dealer to install the shift light. They Could not do it !
Something to do with the fact that the BA doesnt have the typical signal that is used for a tacho, the fly by wire throttle, crank sensor etc. etc. (they lost me on the technical explaination)doesn't support an auxillary tacho
Discussion Starter #12
yeah Mal, SSS have you driven one in manual mode yet??
Discussion Starter #13
my local auto barn guy was going to do it for $70 says he wants car for 90 mins, i have no idea how he thinks that it is going to be fitted.....
I can only say that make sure you're happy with what they are going to do to your ute, and that they have explained it to your satisfaction. That way you are less likely to have some shonky butcher job done.
1 - 14 of 14 Posts
