I've searched and failed to find anything that sounds the same as my problem.
Currently the car will not start, starter motor goes, accessories fire up, but the smart lock LED never flashes.
Unsure where the problem may lay, anything will help :D
in my car ED but has el ecu in it so may be similer, smart lock flashes then i insert key and the smart lock light will light up solid either then or when turned the first click then after 5 or so sceonds if left in that position the smartlock light will turn off indicating whatever test has succeded. If it doesnt turn off you may have a problem or if it is not even flashing at all.
Hope that sorta helps a bit.
6pAc.
###AND EDGT DRIVER###
had a friend in a ed that had a starting problem on of the connection under the dash light tap would fix it short term.
only thing i can think is check the fuse`s and relays
