Hi
I have just installed a new body control module in my fathers 1994 ED Gli Falcon, the starts and runs fine, but the remotes for the keyless entry.
I spoke to ford and they said to to the key to acc and hit the boot release button 3 times and then hit the lock/unlock buttons.
I did all that and nothing happened and the remotes still don't work.
Does anyone know if this is the correct method for programing the remotes and I just got it wrong or is there a different procedure I need to follow?
Regards
frl0173
that is correct, but you have to do it fast! like within 5sec of turning the key to acc you have to press the boot release button those 3 times. wait for the door locks to move, then press a button on each key pad. then turn it off. then you should be done :)
