· Super Moderator
What is happening with it exactly? You can do a PCM Parameter Rest and then relink the BEM using Forscan (What's new) and a suitable OBD scanner such as OBDLink® EX - OBD2 Adapter For ELM327 & FORScan or https://www.amazon.com/dp/B094Z7PBLS or an ELM327 with a Ford Switch (e.g. FORScan ELM327 USB Modified OBD2 Code Reader MS/HS CAN Diagnostic Tool For Ford | eBay ) The process is covered in detail section 15-8 in the factory workshop manual and it is not something you can "wing". You can download the whole factory workshop manual for a small fee for a 72 hour subscription from the Ford site at https://www.motorcraftservice.com
· Registered
2002 au falcon series111
Wow .thats a problem. Thanks for your time and effort though aussieblue. Cheers
· Super Moderator
This post on the Forscan forum may (or may not) help: Parameter reset for AUII Falcon Ute - FORScan forum It looks like a Parameter reset for the AU may not be supported in Forscan and if so you may need to go to a Ford dealer or someone with a high end scan tool.
EDIT: Checking further it seems the full Forscan Window extended licence does do the Parameter Reset for the AU but it wouldn't hurt to confirm that in the Forscan Forum before buying it. Depending what issues you are having, it might be cheaper to just by another used AU BEM noting that often the issues requiring a Parameter Reset end up being due to a faulty/failed BEM.
