I have a 1997 E-350 cutaway on which is mounted a Jayco Class C motorhome. My mechanic and I have found some discrepancies in the instrument panel fuse box.
I compared the fuses from the owner's manual with what is in the fuse box. I found some discrepancies.
In slot # 1, the manual calls for 20 amp, installed is a 15 amp.
In slot # 2, the manual calls for 15 amp, installed is a 20 amp.
In slot # 23, the manual calls for 20 amp, installed is a 15 amp.
In slot # 26, the manual calls for Not used, installed is a 5 amp.
In slot # 28, the manual calls for 25 amp, installed is a 20 amp.
Slot # 1: 4WABS or RABS module Not sure about those acronyms; any guesses?
Slot # 2: 4WABS relay (coil), RABS (diode/resistor), instrument cluster, warning chime
Slot # 23: Cigar lighter, data link connector
Slot # 26: Not used
Slot # 28: Instrument panel power point
I will be asking the PO if he knows anything about these discrepancies. In the meantime, can anybody here provide some valuable information I might be missing? Thanks.
Slot # 26: Not used
