1 - 8 of 8 Posts
Hi.
1990 Focus 45k 16i.
The faults are;
1)The speedo drops to zero when travelling .
The car then splutters and the speedo corrects itself.
I believe this to be the speed control sensor ?
2)But also occasionaly at the same time the digital mileage
readout turns to dashes not figures. ( goes blank )
Is this a different problem or related to the speed control sensor ?
Both problems correct/return at the same time.
Any thoughts welcomed.
Best regards
Discussion Starter · #2 ·
what engine.... and are you in the uk or us?
MR Freeze wrote:
> Hi.
> 1990 Focus 45k 16i.
> The faults are;
> Best regards
16 injection. zetec
We are in the UK.
"Pop-N-Fresh" <[email protected]> wrote in message
news:[email protected]
> MR Freeze wrote:
>> Hi.
>> 1990 Focus 45k 16i.
>> The faults are;
>> Best regards
Discussion Starter · #4 ·
sounds like a bad ground... make sure the batt terminals are tight...
if it happens again... have the codes scanned
MR Freeze wrote:
> 16 injection. zetec
> We are in the UK.
> Cheers
> > MR Freeze wrote:
> >> Hi.
> >> 1990 Focus 45k 16i.
> >> The faults are;
> >> Best regards
Discussion Starter · #5 ·
You probably just need to clean the transducer on the tranny, WBMG
mike hunt
"MR Freeze" <[email protected]> wrote in message
> Hi.
> 1990 Focus 45k 16i.
> The faults are;
> Best regards
Discussion Starter · #6 ·
MR Freeze wrote:
> Hi.
> 1990 Focus 45k 16i.
A very early example... :)
> The faults are;
> Best regards
Without any doubt, the VSS (Vehicle Speed Sensor) has failed. This is
causing both faults. It is *very* common on early cars.
Bottom line - 100UKP for a garage to replace it, or 25UKP and a fairly
tricky 45minute DIY job.
The replacement will be a modified one, to stop it happening again.
If you decide to have a go, there is plenty of archived info in this group
to help. Google here for VSS. Note that the retaining pin generally gets
mangled during removal so make sure to get one as well. Helpfully, dealers
don't normally keep them in stock!
Post again if you need further help.
Chris.
Remove prejudice to reply.
Discussion Starter · #7 ·
> Hi.
> 1990 Focus 45k 16i.
> The faults are;
> Best regards
This just happened to me too. Speedo died and all lights came on the dash
and odometer went to "----"
Ford replaced the car's computer - this didn't fix it. Then they replaced
the instrument cluster and some other computer associated with it.
Glad it was under warranty as it took them 3 days to figure out and fix.
Good luck.
MK
Discussion Starter · #8 ·
Thank you all.
Jeff
> Hi.
> 1990 Focus 45k 16i.
> The faults are;
> Best regards
1 - 8 of 8 Posts
