Hi all, got a 97 merc 4.6 with 90k miles that ive had for a number of years. I out the car in storage when i left the state 3 years ago and came back last year to retrieve it to find a no start issue. I did regular maintenance (plugs wires oil change air filter fuel filter) i diagnosed a bad fuel pump and swapped it out, siphoned out the gas at the same time. Started right up first crank. Over the next few months ive had a gas smell in the car at all times, and some intermittent cranking issues. It sputters turning over and sometimes wont start as the battery dies. No check light. Until last night if i had my truck hooked up with cables it would start up pretty much no problem, the last week it was doing pretty good starting on its own with no jump but last night i went to crank and even when i had it hooked up it just keep cranking and sputtering with no start/would start and stall immediately after. The alternator and starter are good and were replaced just before storage and certainly has more signs of a fuel/air issue than electrical. Was possibly thinking clogged filter/injectors, bad seal on the fuel pump or sticky iac, possibly bad regulator. Its at a gas station now and im going back in a few hours to see what i can figure out. Any insight would be appreciated.
