1 - 19 of 19 Posts
Australian Falcon Member
Hi all I'm new at this.
I have a standard EF exept for 16x8 ROH ZS wheels and JVC cd unit. I just want to know what I can do to take out the sponge feeling in my brakes.
Ta.
CEO - The BSR Group
My suggestion would be to try some Bendix Ultimates pads for a start. If these are bedded in properly, it should improve the pedal feel quite a bit, as well as stopping performance. The next step after this would be to grab hold of some DBA rotors, at least for the front end. This too would help pedal feel and stopping power. Not sure on prices for the pads, but I paid something like $90 for front pair and $80 for rears.. and as for rotors, I paid about $160 each for front drilled + slotted ones, the slotted only were about $130 each from memory.
Check out www.discpads.com.au for latest prices.
Wow I heard that disks cost abit but thats a little out of my non-existant budget.
But that has given me something to play with, late this year early next looks good for spending on the car.
Ta.
Australian Ford Member
Ta.
Not familiar with EF so don't know if spongy feeling is a problem with them. If not, changing brake fluid is first step for any spongy pedal, and cheap. Brake fluid absorbs water even from atmosphere and it doesn't last forever. Although hardly anyone does it, fluid should be changed every couple of years minimum, so if it's never been changed it's long overdue.
300+rwkw DC LTD Member
My LTD's pedal is spongy too. I was told it was a Ford thing. I am seriously looking into upgrading. I heard you can get a AU upgrade kit or even a Tickford kit :)
Could it be a ABS thing? I don't know.....
T5 Expert Operator
About EF brakes i can comment on the following,
For me a slight spongy feel is actually pretty good, much much better than the EB we had that felt very very wooden as though the pedal was dead like as if it had a lack of power assistance.
My brake rotors are on th wear limit and i've got Bendix Standard on them. For daily use there ok pads, very little noise, doesn't chew rotors and disc brake dirt virtually nonexistent.
In hard constant braking at low speed(ie, going down Old Bathurst Rd to EmuPlains at the foot of the mountians) i do feel they fade.
But braking hard from high speed i feel there quite ok. Except when braking from 140km/h in a back street after a drag and stopping in time for an intersection, brakes were on the limit then. :nuts: :nuts: :nuts:
Craving Boost
my xh ute and my old blokes ef has the spongy feel as well. Both auto's does anyone have a manual box with spongy brakes?
96 EF Futura
yeah every falcon I have driven since ABS was standard has a slightly spongier feel than the earlier E-Series, which actually felt like you were pressing blocks of wood onto the rotors. My EF's brake pedal is spongey but pulls up very very well and has plenty of pedal, ( doesnt go anywhere near the floor etc ) I think alot of it has to do with the ABS, but I will be flushing my brake fluid and fitting DBA slotted rotors up front and bendix advance all round
It's a kind of loose feeling. The pedal goes in with very little resistance. Usually caused by air pockets in the brake lines.
You won't be saying that when you need to stop in a hurry. :p
96 EF Futura
if your pedal is too hard it could very well be that your booster is not operating correctly, check the vacuum lines and also make sure there are no cracks in the casing, damn plastic boosters
5 Litres of Fun
partsguy said:
If your cars running genuine pads then you have Bendix Ultimates.....same spec.
I do believe the standard Ford pads are more in line with Bendix Metal Kings... You can notice an inprovement over stock pads or Metal Kings with Ultimates.
Roll, Crash and Smash
Yeah i know what you guys mean by the EB-D having wooden brakes. I have one and quite frankly it gives me the shits. what can be done to get rid of the "stepping on a brick" feeling?
1 - 19 of 19 Posts
