I am having trouble taking out the starter motor in my 1924 Model T. I have removed the 4 screws and it still wont budge. What can I do next to try to get it out? Could it be the bendix drive gear stuck on the flywheel? Thanks for any help or suggestions.
Always the student
Block of wood and a hammer, tap the starter. I would tap right where it bolts up, then work your way back on the starter.
Discussion Starter · #4 ·
Thanks for the replies.
I did try using a hammer to loosen the starter but it wont budge. I am nervous to hit it any harder but I suppose I have no choice. I just don't want to crack or break anything in the process. Any other advice or should I just muscle up and go for it?
Can understand your worry on breaking / cracking something . Cant get any heat round about aperture or try soaking overnight with a penetrating oil ?
A '24 model should have provision for a crank handle as well as a satrter motor so after disconnecting the battery try rocking the crank handle slightly and gently back and forth this should free the starter and it may even fall completely out.
