U
Unregistered
·Guest
99 f150 4.6L
Turn the key on the ignition, i can hear the relay click for the power to the strter, i hear the fuel pump, all dash lites and gauges are working but the starter isnt engageing to turn over the motor. Its not loading the battery or the electrical system or anything, seams like a contact somewhere or a relay is sticky. If i turn the key a few times to the strt pos. it finally fires up. I know if i take it in they will just start replacing everthing under the hood, the one time it did it i just wiggled all the relays under the hood and it started the next try, tried that trick the next time and it took me turning the key 5-10 times. Does anybody know if there is a relay under the hood that will csuse this or is it the starter. It has done this maybe 6 or seven times but its becoming more frequent.
