Hey guys looking for some insight. I have a 2014 Ford Focus se and it dosent start the first time, I’ll turn the key back and try it again and no turn over again, I’ll give it a third shot and then the car turns over and starts. The entire time trying this the car does have power from the battery and clicks once then not again. I’ve replaced the battery, the starter itself, and the starter relay. My next plan is the alternator but I don’t know if that is exactly the problem. Anyone got the same problem or any ideas?
Check and clean battery terminals and ALL grounds . Check wiring at starter .Load test alternator first as you could be replacing it when not needed . Check your battery voltage .
