Mini Tempo Member
Me and My mom both own Tempos, but there is something wrong with hers. The key is hard to get into the ignition and the blinkers don't work unless you jiggle and hold them down. Is the only way of fixing this replacing the entire steering column? or is there something else that I could do? How difficult is this problem to fix by myself or should it be taken to a garage? Also, if its not a hard job to do what tools would I need to do it? I've never worked on a car a day in my life and the only thing to help me is a haynes manual.
Tempo GL Member
Suggestion
You might try this:
Remove the plastic cover of the steering column. There should be a couple of screws holding it on. Once you get it off there should be a large wireing connector with lots of wires on it. I suspect that your problems might be with this connection. See if it is loose. It may be. If it is just pop it back on. YOu could also check it for corrosion.
Hope this will help
Ryan
Tempo L Member
The entire signal lever assembly and/or ignition tumbler (where you put the key) can be replaced without having to replace the column. You probably have to get the tumber from ford, but the lever assembly can be had quite easily from a junkyard. As for a CV joint, prices vary from place to place so the best way to find out is to call a couple of places to find out.
You can get boot kits where you basically take apart the joint and clean/inspect and repack the joint, these are relatively cheap. I don't think you can repairt the joint if its gone bad though, just repack it. You may have to get an entire drivaxle then, or you could go to a junkyard and pick that up too, then go get some new boot kits and repack the CV joints as long as the joints are good.
HO V6 XR5i
CV Joints
I would definetely stay away from those "EZ" boots, the ones that are halves and come together. Repairing CV joints is cake. If the bearings are dry, just replace the bearings, repack, then replace the boot with a QUALITY one and clamp the clip and voila. Joints are so cheap nowadays that it may just be more convinient to get a remaned one at the store......whatever you do if you do replace them yourself.......DO USE the circlip, I know a lot of mechanics that get lazy and leave the clip off so it can slide in the diff easier.....bad things happen if you don't use that clip
