Woooohooo !!!! Nipper.... With a system like that, Id never leave the car !!!!
What about the bar fridge, fax machine, and microwave oven !!!!
Hehehehe...
Mine is no where near that sophisticated, but anyway here it is.
Clarion CVX-6451 In Dash TV set - $600 Au (Imported from Japan)
Sony XR-C7200 - Cassette Deck and 10 Stack CD $800 together.
Sony Playstation II - $650
240 Volt, 80Watt Inverter - $60
1 x 100Litre Box, Selaed 18mm MDF, and carpeted with
Box mounted 400W RMS 4 Channel Audiogods amp - $400
2x Response 12" 250Watt RMS Dual VC Carbon Fibre subs - $420 (pair)
2 Low Pass 12Db passive octave crossovers, <400Hz
(Box tuned for 22Hz, Unknown Max SPL) - Box is only used for drifts..and is not left in the car because of weight, and Boom Boom
Rear parcel tray has
1 x 10" 160W RMS Carbon Fibre Response Sub - $120
2 x 6.5" 80W RMS Carbon Fibre Response Woofer $110 (Pair)
2 x Response Ferro Fluid Tweeters 40W RMS - $32 (pair)
2 x Audio Gods Tweeters (>22K top end supplement) $20 (pair)
1 x Standard Ford amp (Free with premium sound system)
18mm MDF wood, covered in standard Ford Carpet, and sprayed speaker (non badged) grills, to match interior.
All speakers use 12Db passive crossovers.
Without the Sub, Box, and Audio gods tweeters, Frequency repsonse is 80Hz-28Khz +-3db
With Sub, and Tweeters, the figure is 48Hz-32Khz +- 6db
For the Front-
2 x Response Ferro Fluid Tweeters 40W RMS - $32 (pair) hidden in the crash pad.
Door speakers are standard, but have 12db Band pass crossovers to cut frequencies below 600Hz and above 8KHz
1 Voice activated Motorola Hands free kit, with data cable. (For use with my laptop, which also connects to the Inverter, In Dash TV, and stereo system.
I have bought the stuff over the years, from sales, specials and the like, to keep costs down. (The TV was the biggest bargain !!!)
The speakers, Deck, and Stacker are now 5 years old, and still going strong. Im also an Electrical Engineer, and did Audio Engineering as a side hobby, meaning I designed the box, Crossovers, and fitted all components in the vehicle.
The system so far has cost me about $3200 all up, and I can watch DVD's, play DTS audio, playstaion 1 and 2 games, CD's, tapes, and Radio.
