A lot of people have been asking about one step down.....the lesser model is the blueline series... here is the info... these run 119.95 a set.
the long tubes are 6 inches shorter and theyre not quite as brite because the transformers are built in and a little less powerful... they still get the job done though and for a little cheaper.
Each BlueLine Series under car kit comes with 2-48" tubes for the sides, 2-30"
tubes for the front and rear, built in transformers in each tube to simplify
installation, all necessary installation hardware, instructions and a no hassle
lifetime warranty (excludes breakage).
Each neon bulb is encapsulated in high impact Lexan® to withstand the
toughest road conditions and elements. Available in 9 exotic colors. The
BlueLine Series was designed for the do it yourselfer and hobbiest in mind.
Quick installation and consumer friendly pricing make this a winner for any
Auto-Neon® entusiast.
BlueLine Series tubes are not limited to undercar application they are also great
for truck bed rails,engine compartment,anywhere imaginable (simple 2 wire
installation) basically any application which requires a longer lighting
configuration.
