1 - 11 of 11 Posts
Pursuit Reincarnation Dog
How does this happen? You take a new XR8 220kW engine and remove it from the car. Herrods remove the entire subframe from below in a reversal of the assembly procedure used by Ford. This minimises risk of damage etc.
Discussion Starter · #2 ·
Here is the removed assembly viewed from the front/side.
The same but viewed from the rear.
Discussion Starter · #4 ·
The stripdowm begins from accessories to top end with the aim to get down to the real business - the short engine.
Discussion Starter · #5 ·
And here we are. The area where all the action is going to take place - the bottom end....
Discussion Starter · #6 ·
Note the standard bottom end has two bolt mains and along with the cast iron crank has I-beam rods and basically what you expect in an engine bound for a 4WD (Ford Exploders).
Discussion Starter · #7 ·
In preparation for the reassembly, a Stud Girdle is trial fitted whilst the bottom end is still in place.
Discussion Starter · #8 ·
After complete disassembly, the block is chemically cleaned and then sent for machining and follow up treatment. The result is a fully machined block with best tolerances ready for the new parts being fitted.
Go to part 2 for the reassembly story!
Discussion Starter · #10 ·
gtho4 said:
There was a time they used to paint the engines.
Anyway nice pics there Pete. :cool:
Yeah - Herrods fixed that during the reassembly.
1 - 11 of 11 Posts
