1 - 14 of 14 Posts
****~~~HELP~~~~***!!!!,
I recently purchased a nice 1972 ZF Fairlane which has a 351 cleveland in which the Distributor is corroded in place.By that I mean that is it impossible to take it out of the block.I have tried soaking in the usual gear like Rostoff,Rp7 etc, also have tried lighly tapping to try and turn it hoping to break the seal all to no avail.(Just keep breaking small pieces of the collar)
The timing is out to buggery.
I'm told that if I snap it the motor has to be stripped to be able to get to the underneath of it & push it up that way.
Does anybody have a sensible solution as to how to get the bugger out without breaking it ?
Ho-downer
351 ZH
I would advise you to pull the engine out anyway , strip it down and see what you have as I have seen them old motors run hot due to all the water chambers clogged up with shit, better to find a problem than trying to fix it after it goes bang
Ta mate ,but I don't want to go to that extreme as the motor actually runs quite well. It is actually on LPG which combined with the timing being out makes it run hot but not excessively.
Always the student
Can you turn the dist? Soak with some marvel mystery oil for a few days. Somw sharp taps may break it loose.
Discussion Starter · #6 ·
Thanks for the tips fellows.The dizzy works ok but the actual housing of it is stuck. I guess because water etc sits in that particular valley & I don't have any mystery oil however have just put some fine machine oil on it & will leave it for a day or so before using the stilson.Cheers
Ho-downer
G'day, I know I'm a few years behind but I've got the same problem with almost the same motor scenario, great motor(has less than 10,000kms on it) but can't adjust timing. I've been soaking it in diesel & Inox, to no avail, and am now giving vinegar a shot. I've had my engine crane on it and almost lifted the front of the F100 off the ground by the dizzy...it's well & truly seized!! Does anyone have any other methods they can recommend?? I'm going to give the vinegar a few days but after that I think I'll have to remove the radiator, water pump housing etc, give myself some room and give the stilsons a try. Any suggestions??
Cheers,
Paul.
G'day, a quick update for those that are interested. Got the dizzy free, had to remove the thermostat housing to make a bit more room got a small set of Stilsons onto the dizzy and with a bit of slowly increasing force it finally moved. A bit of wriggling back and forth and it was eventually free. Truck is finally running on gas. Yee Hah.
******* Alcohol Racing
other option would to drop the sump, drop oil filter and gently tap the dizzy shaft upwards
thats what i meant :p..was a long day at work followed by a few cans..hands were typing faster than brain could think
I'm with Snap on this one, i would be looking at an engine-out scenario. You have to be sure that you don't have corrosion moving further down the body of the distributor to inside the block. Also, the distributors aren't meant to be tightened down too hard to the block, they're meant to sit firm on the rubber seal but be able to take a certain amount of vibration from the gear running on the cam.
Cheap insurance is at the expense of a few gaskets-pull it down, check it properly
1 - 14 of 14 Posts
