1 - 14 of 14 Posts
When I run it a bump in the road, I'm beginning to get this subtle vibration, that sometimes goes away when I runover another bump, or slow to 10 mph. Any ideas...
Along with the 250k miles, the wheels have been upgraded from 16in to 18in, and tires from 265 AT to 33 MT
Look for front end wear. Start with shocks, tie rod ends, and bushings. However, I would expect some vibration after hitting a bump in any truck. My 2020 4X4 F 250 Lariet has less than 100 miles on the odo and it vibrated when I crossed the RR tracks this morning.
I believe that there is an issue with the hubs for the four wheel drive. I'm going to chance from an auto locking to a manual lock, and from what I've learn, should correct abby issues. I'll update after some time with the new hubs.
Discussion Starter #10
It's been about a week and changing the hubs did not correct the issue
Hubs would not normally cause vibration only when you hit a bump. Have you checked the other items mentioned for wear? With 250,000 miles, normal wear IS present and will cause the slight vibration you mentioned.
Discussion Starter #12
I was leaning towards transfer case or brake system. As I slow to 15, I can hear a metallic click as if something is disengaging or falling back into place.
1 - 14 of 14 Posts
