1 - 7 of 7 Posts
hi everyone, I have a 64 landau bird in my barn with a good drivetrain and interior but a rough body. recently I found a 66 landau shell that has had all the major body work done and primed but the owner lost interest and it has sat in his garage for five years. are the 64 and 66 shells the same? will the front sheet metal, suspension and interior work in the 66? thanks
You may ave to drill new trim holes, but it seems that the sheet metal is the same.
Registered User
64 and 66 are in the same generation, but there are some differences. Steering components are different on the 65-66 models from the 64. The spindles on the 65-66 are different because they use disc brakes. The front end sheet metal is unique to the 66, and would require major modifications for the 64 pieces to fit. While both your 64 and the 66 are Landaus, 66 is unique because it has the blind quarter roof, which means the headliner is different. The remainder of the interior is mostly bolt in, but the wiring differs slightly, the Ammeter circuit in the 64 was a sore point, most specifically at the firewall connections.
How bad is your 64's body? There are patch panels available for the most common spots on the 64-66 generation. 1/4's, trunk pans and sides, floor pans, etc. If it's really that bad, and the 66 your are looking at has all of the parts consider parting out the 64 and using the money earned towards the 66. Here's another forum specifically for T-Birds: Vintage Thunderbird Club International :: Index
The 64 has the usual spots underneath (floors and trunk) gone. Not sure if this is common but the top of the rear fenders behind the roof are also rotted out.
Registered User
Well that's the top of the 1/4 panels. The full height 1/4 available include the areas you describe.
Thanks for the help. After you mentioned the front metal being different I got my brother to come over with his finished 66 thunderbird convertible and we put it beside the 64. There is quite a few small differences in the way the parts bolt together and it looks like this might be more trouble than I thought I would save. Besides, I need to finish a 52 international l160 that I am restoring, restore a 62 Chevy Apache for a friend and upkeep on my 70 mustang and 77 f100 before I can think of starting this bird.
Registered User
You sure have allot on your plate! LOL... Well, whenever you take the plunge, the VTCI forum is a great source for info.
1 - 7 of 7 Posts
