1 - 15 of 15 Posts
Ford Member
Hi,
I don't know what is going on but the handling on my AUII XR8 seems to be a bit off.
I am thinking of putting a front and rear sway bar to decrease what I feel is excessive body roll.
Is this going to be a good modification?
Am I being a spoilt bastard?
Pursuit Reincarnation Dog
TheBow said:
Hi,
Well, I've driven an AU2 XR8 Ute and they go good. Nothing like the IRS sedan over rough stuff, but very good all the same.
Before you spend money on hardware, I always suggest a check of wheel alignment with a trustworthy and committed alignment specialist. You'd be surprised, very surprised!
Ford Member
Hmm,
Good idea I hadn't thought of that, I got a quote from whiteline for front and rear sway bars fitted and was about $400 whihc I guess isnt too bad considering it is hardware for a car.
Anyone know of any good wheel alignment places in Sydney as its probably not a bad idea even though I have only done 9000km's since new.
Oh, only 9000kms hey? Well, if I told you the readings on my car from the day I got it you'd wanna chuck your guts up.
I use EastCoast Suspensions at Kirrawee. He charges a bit extra but I know he does it right. The person to talk to is Dave Falson. You should only need front end so around $50.
Another good place I have used before is Heasmans at Sydenham on the Princes Hwy.
Territory TS - AWD
I hope I'm not insulting you here TheBow but have you checked tire pressures. The simple things make a heap of difference. This and the alignment make a world of difference, agree with Pete there.
Ford Member
Not at all, I check the tyres every week so that is not the issue but its due for its weekly check this week so I'll see.
I think the problem is that when you get something new and use it then it becomes normal for you.
After a while your expectations rise and you start to think its getting crappy when in fact nothing has changed at all.
Tyre pressures! Aahh yes. I use 34 front and 31-32 rear (helps that little bit of oversteer I like mid corner).
T5 Expert Operator
Pete,
I've recently tried the softer rear end pressure to front, and must say it's better, gives the ass end grip especially in the wet.
I had my tyres on close to 36 front and 36 back a while back and in the wet accelerating in 4th gear up hill round a corner back came out.
:crazy1: :crazy1:
EL-Phat said:
Whats the recommended tyre pressure for a set 235/45 17" tyres?
It will be on the tyre placard on the car. I think it's 28 or 30 psi. Higher pressures are listed for high speed or heavy loads.
EF GUY:
Your car will be even more sensitive to rear tyre pressures due to the traction thing with leaf springs. Softer pressure gives better traction in a straight line but reduces the cornering stability as the edge of the tread gets loaded up.
I find it interesting so many people judge a tyre by its tread pattern. It's what is hidden that matters (the construction).
T5 Expert Operator
EF GUY:
Yeah i noticed that ford tend to have their reccomended tyre pressures too flat for my liking.
Pete,
Might do further experiments with tyre pressure combos, this evenings run should be a good test for the Yoko A539's.
:s2: :s2:
Ford Member
Discussion Starter #12
Yes, they are too flat.. I pumped them up a 34 psi all round and the car seems quite a bit better now.
Beats spending $$$ on sway bars then although not as much fun.
Thanks for the info
European Member
If you wanna get the most out of tyres go 40psi front 38psi rear COLD pressures. You can go the 38/36 but the above is the go.
T5 Expert Operator
Phoooooooooa, so high, what car you got?? My EF Falcon with 36 36 was super scary in the wet. Put my foot down in 4th gear in the wet and i went sideways.
European Member
I've got an AU2 XR6. Admittedly I've got 16in rims with Yoky 509's but these pressures haven't posed a prob yet. I know several people w/ XR8's running these pressures w/ no probs.
1 - 15 of 15 Posts
