Hi Guys,
Just noticed two nights ago that my shift lever is a tinny bit loose. To best describe it is, in neutral position before the forks move the lever has a slight movement, is this normal or can it be fixed.
I've taken the knob of the lever before and also taken the boot cover off. The actually lever thats bolted to the shift is tight, so there must be something on the shifter that goes into the transmission thats a touch loose. Does anyone know if it can be fixed without pullin the trans or centre console apart.
If so how do i got about it. I hope i don't need to re-con my trans.
I remember when the clutch was done before they tightened it.
Thanks in advance Guys.
