I got really curious about this, and studied it for a long time (I'm an
engineer). There was a good thread on this at woodall's RV forum. I have
found no frank discussion of it by anybody who has broken it down into its
component forces. It's hard to explain it using ASCII here. But my opinion
is this:
First off, it's clear that trailers can amplify their swaying until you
crash. They don't do it all the time, but they can, and that's what
interests me. They have no power of their own to bring to the table. The
energy to do this comes from the tow vehicle. The trailer sways like a
pendulum, sort of (I admit the forces holding a trailer back are not exactly
like gravity in this analogy). A pendulum can be powered by a wide variety
of motions. One of those motions is moving the pendulum's pivot point side
to side. I think this is the motion we want.
The forces on the trailer come from its tires and the tow vehicle. I was not
interested in any other forces. "front loaded" trailers are trailers where
the center of gravity is in front of the tires. When the tires are pushing
the trailer sideways (during sway), the center of gravity is in front of
that force. Since the side force doesn't go exactly through the center of
gravity, the weight of the trailer pushes sideways on the tow vehicle.
The inertia of the swaying trailer pushes the tow vehicle from side to side.
The difference in loading is simply this. If the center of gravity is in
front of the wheels, it pushed the tow vehicle one way, and if it's behind
the wheels, it pushes the two vehicle the other way. One cancels the sway,
and the other amplifies it.
"Nehmo" <
[email protected]> wrote in message
news:
[email protected]
> "Pull-behind" trailers are trailers that connect to the tow vehicle by
> a ball (or other attaching arrangement) on the back of tow vehicle and
> a trailer hitch on the tongue attached to the front of the frame of the
> trailer. If the trailer is improperly-loaded into a tail-heavy
> condition (in other words, the center of gravity is to the rear of the
> center of the axles) arrangement, it will sway from side to side. But
> why? Why would tail-heavy conditions cause such behavior? The weight on
> the tongue would be negative, but I still can't understand the swaying
> mechanism.
> (||) Nehmo (||)
