Aussie Pete said:
Right on Jase.
We had a number of trials and in one case on a heavy duty diesel the vendor was doing the testing and feedng us results. The oil tests showed great results, but I got to talking to one of the other engineers and we smelt a rat. We took an oil sample ourselves and sent it to Mobil for analysis. The metals were way high and the neutralisation number so far off the scale it was a joke.
We pulled the engine down after telling the vendor to take off. It was cactus! And I mean the crank was a throwaway for starters. $80,000 later we proved the stuff was junk.
Don't believe these snake oil merchants!
Unfortunately this generalisation about "snake oils" is the reason that EF will not get the recognition it deserves. Don't get me wrong I was exactly the same. I refused to believe anything was capable of reducing friction that much.
I have seen the results of this substance and it's nothing short of amazing. There are truck companies using this in the north west and have reduced diff and trans failures to ZERO! Formally they would get only 15 000 K's from a Diff. They've even put a few drops in the wheel bearings(which previously failed after 50,000) and have since had NO failures.
These guys tried oil coolers,changing oil after each run, other additives the lot. They've logged diff and trans temps and with EF observed reductions of 80 to 150 degrees!
Oil analysis reveals wear metal content a fraction of what it was.
One Truck guy in Esperance has gone from 1.4K/Litre to 1.1K/Litre fuel economy.
Pete.
