I'm looking at putting a 75mm aftermarket throttle body for a 86-93 Ford Mustang V8 (I think engine and ancilliaries similar to EB V8) onto a EB I6 manifold. Anyone know whether the IAC (idle air control valve) from the EB I6 T/B will fit a Mustang (or EB V8)Type T/B.
I want the 75mm T/B as the 3" turbo ducting will nicely fit and flow with a 75mm t/b. I realise the manifold will have to be moded to make the T/B fit. I just want the IAC to work as normal.
100 SPEED LIMITED SILVAEA
why not look into some au series 3 xr throttles they are a 75mm item (or is it 70?)
they should accept the isc you want to run.
cheers.joe.
I think the tb mounting is rotated 45 degrees and I believe the mounting is the same but the different angle may make the isc foul when you bolt up the tb.
