does anyone know the timing specification of a 351 windsor how many deg before or after tdc should they be for i guess keeping it cool
Two SC 61's = trouble
Depends ..But start at 10* btdc
forgive my ignorance 10* before or after unsure , i dont have any timing marks on my balancer , just the one for tdc
You sure ??? O/K then I"ll stick my head out...Say 12mm infront of tdc it should atleast be fireing..You can get some stick on stuff that shows degrees...Another way is mark on ballancer where you want max timing, then mark..Sat you want 28* total max?? Then mark 28*..Then dajust timing at 3000 rpm or where max advance is in rpm range..This is the best way to tune on h.p engine as setting at idle you don't know what is happening and relying on correct settings in dissy....Or do both and check with timing light on both marks???
