Got Boost?
Ton's of 2nd gen engine and misc. parts for cheap! *PICTURES ADDED*
Ok, I have a lot of parts here, most from a 96 GT unless otherwise stated:
o 1 front head with 49,000 miles on it
http://www.geekazoids.net/~images/head_copy.jpg
o 1 egr solenoid valve(located below the throttlebody on the block) in good shapeSOLD!!
http://www.geekazoids.net/~images/egr_valve.jpg
o Cam gears
http://www.geekazoids.net/~images/cam_gears.jpg
o Stock crankshaft pulley
http://www.geekazoids.net/~images/pulley.jpg
o Complete engine wiring harness
http://www.geekazoids.net/~images/.jpg
o Throttle positioning sensor
o Front exhaust manifold with heatshield and gaskets
http://www.geekazoids.net/~images/manifold.jpg
o EGR tube off rear exhaust manifold
o Front and rear valve covers (Ford) can be painted and clearcoated with high temp paint for an extra $12
SOLD!!!!!!!! SOLD!!!!!! SOLD!!!!!!!!
http://www.geekazoids.net/~images/valve_cover.jpg
o Rear timing belt cover
http://www.geekazoids.net/~images/timing_cover.jpg
o Water pump pulley
http://www.geekazoids.net/~images/water_pulley.jpg
o VRIS solenoids from back of intake manifold
http://www.geekazoids.net/~images/egr_controller.jpg
o Backseats from 93 GT, Black with gray striped centers, perfect shape
http://www.geekazoids.net/~images/backseats2.jpg
o Rear seatbelts from 93 GT
o Factory Amp from 93 GT premium sound system
o Brake fluid resevoir
http://www.geekazoids.net/~images/brake_res.jpg
o Fuel lines, the one that goes to the main banjo bolt
http://www.geekazoids.net/~images/fuel_lines.jpg
o Stock oil cap from PGT
http://www.geekazoids.net/~images/oil_cap.jpg
o Coned Throttle body
http://www.geekazoids.net/~images/tbclose.jpg
o More to come, can't think of any more right now, but I will update
Please email me with offers at [email protected]
Thanks!
"oh, you were racing?"
o VRIS solenoids and egr solenoid from back of intake manifold
The EGR parts here are different parts you're talking about right? What exactly is the 2nd part(EGR solenoid form the back of the intake mani) cause I've replace my EGR sensor on the valve itself, and i am still have EGR problems.
Got Boost?
The first part listed is the bigger part that has vacuum and electrical lines going into it. The 2nd one is the vacuum part that runs it, it is a small (1X2 inch) piece that is located next to the two pieces that run the vris actuators. I know the vris pieces like it are $52 from ford..but I wouldn't charge nearly that much of course...but if you'd like to try it out to solve your problems..just shoot me an email [email protected]
Thanks
Got Boost?
Discussion Starter · #6 ·
Sold stuff!
EGR equipment sold along with the volvo intercooler ;) Keep it coming guys!
