After scrubbing the chassi onto a rather large concrete hump... damage -> dented chassis support. Anyway having look around I saw the upper trailing arm which is connected to the rear axle has another two bolt through option. At the moment the upper arm is connected to lowest bolt thru. Does anyone know what the middle and top thru connection is used for?
I am not sure of what it does but Im taking a guess its there to hold the body stiffer when the axle is see-sawing.
Is this right?
