Hi, I have a '97 Ford E250 with a new 4r70w transmission in.new speed sensors, new range sensor, and it still wont get in gear and move. It will barely move if i rev the engine. New cooling lines. One leaks.
It basically is acting very similar to a bad shifting solenoid but its a new transmission. And this is similar to how the old transmission was betaling. Any ideas?
Pics and videos are available to aid troubleshoot this MAJOR DELEMA.
New transmission is basically acting as the old one just not leaking from the torque converter pan anymore.
When it was filled was it run through all the gears? What’s the fluid level look like? Did you verify everything is plugged in?
If installed and hooked up correctly , contact your supplier of new gearbox about the problem and see what they say or suggest , advise .
