I am replacing the stock 4r70w transmission in my 1999 mustang 3.8 automatic. I am wondering what other transmissions would have the same bolt pattern, that I can use for a direct replacement. Will an f150 transmission work, the 2 wheel drive not 4
Only if it came out of an f150 with the 4.2 v6. You would have to change over your shifter bracket because the difference in shifter location. And be aware that Ford made updates from year to year so it may or may not have all the sensors you need.
