1 - 7 of 7 Posts
Desperate for help here.
I have a 2006 Diesel Transit. It went in for bodywork, (rust removal) and after completion, it would not run again.
Engine turns over, fires and runs for 1-2 secs and then turns off.
We have checked the diesel supply to the injectors - fuel is present.
We have checked fuel is coming up to the pump - OK.
We have isolated the 'immobiliser.
We have diagnosed faults and initially, the Crank angle related to the Injection Pump showed an error. New sensor installed.
The diesel pump has been removed, checked on the test bench, it is performing up to specifications. No issues there.
We have 'cleared' and reprogrammed that PCU and it is now showing no fault codes at all.
We have supplied a new key and programmed it to suit.
The engine still turns over, fires and shuts itself off.
I am really keen to hear about any similar experience that people have had and how you solved it.
Thanks
Andrew
Does it die out quickly as if you turned off the engine or "peter" out? Rapid shut off generally indicates electrical, a slower shut down generally indicates fuel delivery. Neither situation is absolute, though.
It dies as though it had just been turned off.... definitely not a 'petering out' kind of stop.
I'm not versed in the Duratorq at all, but if you jump out the run terminals of the ignition switch, you can see if it holds on start or not. That's one part that can be ruled out.
Mk7s have to generate fuel rail pressure before they start and if it drops too low they shutdown. Could it be oil pressure or the oil pressure switch fault cutting out engine ? It would seem to be more electrical the way it shuts down . Have you checked ALL the fuses and relays The transit changed in that year and there are 2 schematics examples but also variations in different models , countries so might not apply
Ford Transit (2006 – 2013) – fuse box diagram
Year of production: 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013
Location
Left-hand drive
Ford Transit - fuse box diagram - location (left-hand drive)Ford Transit – fuse box diagram – location (left-hand drive)
Right-hand drive
Ford Transit - fuse box diagram - location (right-hand drive)Ford Transit – fuse box diagram – location (right-hand drive)
A – Pre-fuse box
B – Standard relay box
C – Passenger compartment junction box
D – Engine compartment junction box
Pre-fuse box
Ford Transit - fuse box diagram - prefuseFord Transit – fuse box diagram – prefuse
No.
A
Circuits protected
1​
350​
Starter motor and alternator
2​
60​
Passenger junction box power supply – start relevant / Passenger junction box KL15 for Start-Stop
3​
100​
Engine junction box power supply – non-start relevant
4​
40​
Heated front screen right-hand side
5​
100​
Standard relay box power supply – non-start relevant
6​
40​
Heated front screen left-hand side
7​
60​
Passenger junction box power supply – non-start relevant
8​
60​
Customer connection point
9​
60​
10​
60​
R1​
Second battery disconnect switch
[TD]Relay[/TD]
[TD][/TD]
[TD][/TD]​
Engine junction box
Ford Transit - fuse box diagram - engine compartmentFord Transit – fuse box diagram – engine compartment
No.
A
Circuits protected
11​
60​
Engine cooling fan
12​
30​
Trailer tow and trailer tow module power supply (KL30)
13​
40​
ABS and ESP pump
14​
Not used
15​
60​
Glow plugs
16​
60​
Ignition relay (KL15 #3
17​
30​
Starter enable
18​
40​
Ignition feed (KL15) to Passenger junction box (vehicles without Start-Stop)
18​
Not used (vehicles with Start-Stop)
19​
Not used
20​
10​
ABS, ESP, steering angle sensor, YAW sensor supply (KL30)
21​
25​
ABS and ESP valves and control unit
22​
Not used
23​
Not used
24​
5​
Fuel pump (without fuel-fired heater)
24​
20​
Fuel pump (with fuel-fired heater)
25​
Not used
26​
15​
PCM Power
27​
5​
28​
5​
T-MAF sensor
29​
5​
Vaporiser glow plug monitoring
30​
7.5​
Sonic purge valve
31​
15​
VAP pump/UEGO
32​
20​
Vaporiser glow plug
33​
10​
Reversing lamps
34​
20​
Trailer KL15 Power supply
35​
Not used
36​
10​
Air conditioning clutch
37​
Not used
Relay
R2​
Glow plugs
R3​
Trailer tow (KL15)
R4​
Starter enable
R5​
Power feed (KL15 #4)
R6​
Power feed (KL15 #3)
R7​
Fuel pump
R8​
Vaporiser glow plug
R9​
Not used
R10​
Air conditioning clutch solenoid
Standard relay box
Ford Transit - fuse box diagram - standard relay boxFord Transit – fuse box diagram – standard relay box
No.
A
Circuits protected
38​
20​
Rear window wiper
39​
10​
Front and rear air conditioning control
40​
5​
Not used
41​
5​
Tachograph
42​
5​
Headlamp levelling, master light switch (KL15)
43​
20​
Heated front seats
44​
20​
Horn
45​
20​
Auxiliary power point front
46​
10​
Heated door mirrors, if CAT 1 fitted
47​
20​
Cigar lighter
48​
5​
Relay coils supply, power mirrors
49​
20​
Auxiliary power point rear
50​
10​
Main beam left-hand side
51​
10​
Main beam right-hand side
52​
10​
Dipped beam left-hand side
53​
10​
Dipped beam right-hand side
54​
30​
Pre-fuse for dipped beam, main beam, daytime running lamps, tachograph, fuel-fired booster heater blower
55​
40​
Heater blower motor
56​
20​
Power windows
57​
30​
Rear heater blower motor
58​
30​
Front wiper motor
59​
30​
Heated rear window, heated door mirrors
60​
Not used
61​
60​
Ignition relay (KL15 #1)
62​
60​
Ignition relay (KL15 #2)
Relay
R11​
Headlamp dip beam
R12​
Heated door mirrors (if CAT 1 alarm is fitted), power outlet (if CAT 1 alarm is not fitted)
R13​
Headlamp main beam
R14​
Horn
R15​
Daytime running lamps
R16​
Programmable fuel fired heater
R17​
Heated rear windows and heated door mirrors (or heated rear window left-hand side if Cat 1 alarm is fitted)
R18​
Heated rear window right-hand side if Cat 1 alarm is fitted
R19​
Power feed (KL15 #2)
R20​
PJB KL15 (Start-Stop only)
R21​
Power feed (KL15 #1)
R22​
Heated windscreen right-hand side
R23​
Windscreen wiper high and low function
R24​
Rear window wiper
R25​
Windscreen wiper on and off function
R26​
Heated windscreen left-hand side
Ford Transit - fuse box diagram - passenger compartmentFord Transit – fuse box diagram – passenger compartment
No.
A
Circuits protected
63​
5​
Rear parking aid, rain sensor
64​
2​
Acceleration pedal demand sensor
65​
15​
Brake lamp switch
66​
5​
Instrument cluster, PATS supply, tachograph, instrument panel switch illumination
67​
15​
Washer pump
68​
10​
Restraints control module
69​
20​
Exterior lamp switch (KL15)
70​
20​
Battery backed sounder
71​
5​
Exterior lamp switch (KL30)
72​
10​
Battery saver supply, OBDII (KL30)
73​
15​
Radio, navigation unit and phone supply
74​
5​
Instrument cluster, fuel-fired booster heater timer, remote keyless entry supply, interior motion sensor (KL30)
75​
7.5​
Side lamps right-hand side
76​
7.5​
Side lamps left-hand side
77​
5​
Ignition switch supply, battery disconnect switch coils supply
78​
15​
Central locking
79​
7.5​
Number plate lamp, side markers
80​
15​
Front fog lamps
81​
10​
Rear fog lamps
82​
3​
Audio and instrument cluster ignition feed
Auxiliary fuses
No.
A
Circuits protected
Location
83​
10​
Trailer tow moduleLeft-hand side footwell
84​
7.5​
DPF glow plug sensingBelow the engine compartment junction box
AND
Ford Transit (2000 – 2006) – fuse box diagram
Posted on 15 July 2018 by admin
Location
Left-hand drive
Right-hand drive
A – Engine compartment fuse box
B – Passenger compartment fuse box
Ford Transit - fuse box diagram - engine compartmentFord Transit – fuse box diagram – engine compartmentAdditional Relay Box / Boxes Under Expansion Tank
Ford Transit - fuse box diagram - additional relay box/under expansion tankFord Transit – fuse box diagram – additional relay box/under expansion tank
No.
A
Circuits protected
1​
5​
Auto shift manual transmission
2​
Not used
3​
20​
Daytime running lamps, dipped beam
4​
5​
Battery voltage sensor (Diesel engines)
5​
20​
Fuel cut-off switch
6​
30​
Towing equipment
7​
15​
Horn
8​
20​
ABS
9​
20​
Main beam
10​
10​
Air conditioning
11​
20​
Windscreen washers, rear window washers
12​
Not used
13​
30​
Multi-function lever, windscreen wipers
14​
15​
Reversing lamp
15​
5​
Engine immobilisation system module
16​
5​
Electronic engine control
17​
30​
Towing equipment
18​
Not used
19​
5​
20​
15​
21​
20​
Engine management
22​
20​
Fuel pump
23​
10​
Dipped beam, right-hand side
24​
10​
Dipped beam, left-hand side
101​
40​
ABS
102​
40​
103​
50​
Main power supply to electrical system
104​
50​
105​
40​
Engine cooling fan (2.0 l Diesel and 2.3 l DOHC engines)
106​
30​
Ignition
107​
30​
Ignition
108​
Not used
109​
40​
110​
40​
Heated windscreen, right-hand side
111​
30​
Ignition
112​
Not used
113​
40​
114​
Not used
115​
Not used
116​
Not used
117​
Not used
118​
Not used
119​
Not used
120​
Not used
121​
Not used
122​
Not used
R1​
Starter Motor
R2​
Glow Plugs / Cooling Fan
R3​
Horn
R4​
Main Beam
R5​
Generator Cut-Off
R6​
Dipped Beam
R7​
Engine Management (PCM)
R8​
Bulb Check (Vehicles Without ABS)
R9​
Fuel Pump (TDdi Engines), Injector Module (TDci Engines)
R10​
Air Conditioning WOT (Wide Open Throttle)
R11​
Lift Pump (Some TDdi Engines)
R12​
Engine Cooling Fan
R13​
Ignition
Ra1​
Air Susspension Compressor
Ra2​
Engine Cooling Fan High Speed
Ra3​
Trailer Tow Indicators Left Hand
Ra4​
Trailer Tow Indicators Right Hand
Ra5​
Trailer Tow
Ra6​
Diodes
D1​
D2​
D3​
Trailer Tow RH Indicator / or Air Conditioning Clutch
D4​
Trailer Tow LH Indicator / or Air Conditioning Indicator Ligh
[TD]Relay[/TD]
[TD][/TD]
[TD][/TD]​
Ford Transit - fuse box diagram - passenger compartmentFord Transit – fuse box diagram – passenger compartmentAlternative Relay Box
Ford Transit - fuse box diagram - alternative relay boxFord Transit – fuse box diagram – alternative relay box
o.
A
Circuits protected
201​
15​
Instrument cluster, rear window wiper, clock
202​
5​
Heated windscreen
203​
20​
Fog lamps
204​
Not used
205​
15​
Light control, direction indicators, multi-function lever, engine management, ignition
206​
5​
Number plate light
207​
10​
Airbag module
208​
10​
Instrument cluster illumination
209​
15​
Side lamps
210​
15​
Tachometer, clock
211​
30​
212​
10​
Cigar lighter
213​
10​
Rear air conditioning
214​
15​
Interior lamps, electric mirrors
215​
20​
Heated windscreen, heated front seats, auxiliary heater
216​
20​
Auxiliary power socket
217​
15​
Heated rear window, heated exterior mirrors
218​
Not used
219​
30​
Electric windows
220​
20​
Heated rear window
221​
15​
Brake lamp switch
222​
15​
Radio
223​
30​
Heater blower motor
224​
20​
Headlamp switch
225​
15​
Air conditioning
226​
20​
Hazard warning flashers, direction indicators
227​
5​
Radio, ABS
R14Windscreen Wiper
R15Battery Saver / D+ (Only switches on with engine running)
R16Heated Screen Right Hand Side
R17Bus / Rear Door Buzzer Relay
R18Interior Light
R19Rear Door Warning Buzzer (buzzer unit itself not a relay)
R20Heated Screen Left Hand Side (Timer relay)
R21Rear Wiper
R22Heated Rear Window / Heated Mirrors
[TD]Relay[/TD]
[TD][/TD]
[TD][/TD]​
1) Central Locking Fuses: 2 x 15A located under/taped too, steering column.
2) Heater Blower relay is behind centre console (where Fitted),
3) Auxiliary Heater relay is under drivers seat (where fitted).
4) Air Conditioning relay is screwed to rear of engine bay (where fitted), and on LPG models, all LPG control modules / relays arc located behind a removable panel on drivers side dash.
Discussion Starter · #6 ·
Thanks. - I will get that tested and see what happens.
Location
Left-hand drive
Right-hand drive
A – Pre-fuse box
Pre-fuse box
No.
A
Circuits protected
1​
350​
2​
60​
3​
100​
4​
40​
5​
100​
6​
40​
7​
60​
8​
60​
9​
60​
10​
60​
R1​
[TD]Relay[/TD]
[TD][/TD]
[TD][/TD]​
Engine junction box
No.
A
Circuits protected
11​
60​
Engine cooling fan
12​
30​
13​
40​
ABS and ESP pump
14​
Not used
15​
60​
Glow plugs
16​
60​
17​
30​
Starter enable
18​
40​
18​
19​
Not used
20​
10​
21​
25​
22​
Not used
23​
Not used
24​
5​
24​
20​
25​
Not used
26​
15​
PCM Power
27​
5​
28​
5​
T-MAF sensor
29​
5​
30​
7.5​
Sonic purge valve
31​
15​
VAP pump/UEGO
32​
20​
Vaporiser glow plug
33​
10​
Reversing lamps
34​
20​
35​
Not used
36​
10​
37​
Not used
Relay
R2​
Glow plugs
R3​
Trailer tow (KL15)
R4​
Starter enable
R5​
R6​
R7​
Fuel pump
R8​
Vaporiser glow plug
R9​
Not used
R10​
Standard relay box
No.
A
Circuits protected
38​
20​
Rear window wiper
39​
10​
40​
5​
Not used
41​
5​
Tachograph
42​
5​
43​
20​
Heated front seats
44​
20​
Horn
45​
20​
46​
10​
47​
20​
Cigar lighter
48​
5​
49​
20​
50​
10​
51​
10​
52​
10​
53​
10​
54​
30​
55​
40​
Heater blower motor
56​
20​
Power windows
57​
30​
58​
30​
Front wiper motor
59​
30​
60​
Not used
61​
60​
62​
60​
Relay
R11​
Headlamp dip beam
R12​
R13​
Headlamp main beam
R14​
Horn
R15​
R16​
R17​
R18​
R19​
R20​
R21​
R22​
R23​
R24​
Rear window wiper
R25​
R26​
No.
A
Circuits protected
63​
5​
64​
2​
65​
15​
Brake lamp switch
66​
5​
67​
15​
Washer pump
68​
10​
69​
20​
70​
20​
71​
5​
72​
10​
73​
15​
74​
5​
75​
7.5​
76​
7.5​
77​
5​
78​
15​
Central locking
79​
7.5​
80​
15​
Front fog lamps
81​
10​
Rear fog lamps
82​
3​
Auxiliary fuses
No.
A
Circuits protected
Location
83​
10​
84​
7.5​
AND
Location
Left-hand drive
Right-hand drive
No.
A
Circuits protected
1​
5​
2​
Not used
3​
20​
4​
5​
5​
20​
Fuel cut-off switch
6​
30​
Towing equipment
7​
15​
Horn
8​
20​
ABS
9​
20​
Main beam
10​
10​
Air conditioning
11​
20​
12​
Not used
13​
30​
14​
15​
Reversing lamp
15​
5​
16​
5​
17​
30​
Towing equipment
18​
Not used
19​
5​
20​
15​
21​
20​
Engine management
22​
20​
Fuel pump
23​
10​
24​
10​
101​
40​
ABS
102​
40​
103​
50​
104​
50​
105​
40​
106​
30​
Ignition
107​
30​
Ignition
108​
Not used
109​
40​
110​
40​
111​
30​
Ignition
112​
Not used
113​
40​
114​
Not used
115​
Not used
116​
Not used
117​
Not used
118​
Not used
119​
Not used
120​
Not used
121​
Not used
122​
Not used
R1​
Starter Motor
R2​
R3​
Horn
R4​
Main Beam
R5​
Generator Cut-Off
R6​
Dipped Beam
R7​
R8​
R9​
R10​
R11​
R12​
Engine Cooling Fan
R13​
Ignition
Ra1​
Ra2​
Ra3​
Ra4​
Ra5​
Trailer Tow
Ra6​
Diodes
D1​
D2​
D3​
D4​
[TD]Relay[/TD]
[TD][/TD]
[TD][/TD]​
o.
A
Circuits protected
201​
15​
202​
5​
Heated windscreen
203​
20​
Fog lamps
204​
Not used
205​
15​
206​
5​
Number plate light
207​
10​
Airbag module
208​
10​
209​
15​
Side lamps
210​
15​
Tachometer, clock
211​
30​
212​
10​
Cigar lighter
213​
10​
214​
15​
215​
20​
216​
20​
217​
15​
218​
Not used
219​
30​
Electric windows
220​
20​
Heated rear window
221​
15​
Brake lamp switch
222​
15​
Radio
223​
30​
Heater blower motor
224​
20​
Headlamp switch
225​
15​
Air conditioning
226​
20​
227​
5​
Radio, ABS
R14Windscreen Wiper
R18Interior Light
R21Rear Wiper
[TD]Relay[/TD]
[TD][/TD]
[TD][/TD]​
Thanks everyone, Problem solved. It turned out to be a programming issue in the PCM.
1 - 7 of 7 Posts
