1 - 7 of 7 Posts
Should work, how accurate it would be I dunno though.
The CFI amd MPFI setups use the same two-pulse system.
MPFI one pulse operates 3 injectors, 2 pulse operates the other 3. Cfi, one pulse per injector.
Since AFAIK the computer uses a set value to tell it how much fuel was run through on each pulse, you may find it thinks you're using slightly more fuel than you were.
Or, it might be accurate. Each CFI injector should theoretically flow as much in one pulse as 3 MPFI injectors.
Basically, try it. Should work. Helpful huh. :p
Alex
TallyStar said:
were they fitted to EA Fairmonts,
Nope. The Fairmonts came with a basic digital clock. Only the Ghia, Fairlane and LTD scored a trip computer and they were all MPI anyway.
Ash
i am installing one tomorrow so i will let you know how it goes ( ea GL centrepoint -spak dash loom)
1 - 7 of 7 Posts
