ok i have a probe and a mustang the run rough and have the check engine light on how do i get the trouble codes from the computer it is a 90 mustang 5.0 and a 96 probe 2.0
Jumping the TEN pin and GND WILL NOT WORK on a 96 Probe. That is the problem with OBDII cars, there is no easy way to get the codes.Gil Starr said:You can buy the scanner for both OBDII engines or for the probe jump the TEN pin and the GND pin with a paper clip, turn the key to ignition on with out cranking the car that read the flashes. This will determine you trouble code(s). Then look up the codes and you know what's wrong.:s5
