Vintage Mustang Member
I have a '68 coupe that was originally fitted with a straight six engine and 3 speed manual transmission
The previous owner has however fitted a 302 V8 and auto transmission
Problem is I do not know the origin of the engine and transmission!
The casting code on the:
1) intake manifold reads D9DE -9425-DB (spark plugs are 10mm Atlas C36124)
2) transmission reads C6AP 7DO27 - C
As I will need to order some parts and set up the engine timing (any tips here??) any information you guys have will be of great help.
Thanks!,
Kels
Well the intake is a '79, off a Granada Enginge. For the block I do not know without its casting number which is at the back of the right cylinder bank. The transmission is a '66 Full Size Ford. I am not sure what p is for but i would guess its the code for transmission. The 7D027 is a date code for when it was cast.
If you get the engine cast number that will tell you more because the intake could of come from a different engine.
I hope this helps some.
