73falcongt said:
Mmmmm, I thought that timing was advanced the more load the engine was under. Now I've found out the more load the engine is under, the less timing it receives. Why is this? I originally thought that the point of the vacuum advance was to add more timing as the throttle was OPENED, because more mixture requires longer to burn, why is it the opposite way?
Also, I thought that was one reason why old dizzy style cars would tend to ping under extreme load, like uphill or full throttle in high gear, because the vacuum advance mechanism would weaken and allow too much timing advance at full throttle under load. Mmmmmmmm, shows what I know.
My Suzuki I had, the dizzy vac. advance hose I'm pretty sure increased in vacuum, that is it would suck more the more load the engine was under, and the more vacuum the earlier the timing would be. So that hose would suck the most when opening the throttle.
say for instance...you will generally say,have 12 degrees of initial advance when you fire up the engine,that you have set with turning the distributor(setting it to fire the plugs 12 degrees before the piston is at TDC)...
now,as you raise the rpm of the engine,the distributor will add more advance timing via the weights,springs and plate,say for instance another 20 degrees...
this will come in,by a rate and total amount that you can set by making adjustments to weights,springs etc...this mechanical advance will end at a certain rpm and when this is reached,all of your timing(initial and mechanical together)will be in play...12+22=34...so you will have 34 degree's of total ignition timing...
vacuum advance will be a seperate amount that is brought in by means of vacuum,and depending on where you source the vacuum from will depend on WHEN it comes in,and WHEN it finishes...you have two types of vacuum generally,manifold,which is sourced from under the throttle blades and diminishes as you raise the rpm...and venturi vacuum which will increase to a certain degree as you raise the rpm...this is taken from ABOVE the throttle blades...
so,if you use manifold vacuum,when you start the engine up ,you will see the added vacuum advance straight away,typically up to 15 degrees of extra advance to help with the inefficiencies that the chamber see's at lower rpm...and as your rpm keeps raising ,your manifold vacuum will drop along with that vacuum advance...
if you use ported (venturi vacuum),when you start the engine up you see no extra vacuum advance,but just off of idle and into the rpm a certain amount(depending on a few things),the vacuum advance will add the extra degrees and then drop off as the load and rpm raise more and more...
so depending on when all your advances come in and end at, you could have quite a bit at some rpm(all of them together),you just have to work it all out,find out where your manifold vacuum starts to drop out in relationship with rpm and engine load and what your vacuum pod is set at...
but yes,it is used for lower rpm inefficiences,that the engine see's due to poor mixture quality,exhaust dilution,slow air veocity through the ports,things like this,that as you increase the throttle angle,all tend to get better,hence the engine dosen't need that extra vacuum advance any more...basically...
