1 - 8 of 8 Posts
'77 LTD, 351 M: :AAHHH:
In the process of changing my valve seals and rear main oil seal. Both without removing the engine, which I don't have the equipment for.
:fly: I've heard stringing a length of soft, cotton clothesline through the sparkplug holes and rotating to TDC for each respective cylinder in the firing order as an alternative to compressed air. How effective is this at keeping the valves from dropping? Anything I should watch out for / beware of?
PS: the trick is to jam the rope up against the valves by turning the crnak by hand on the compression stroke.
Registered Abuser
Dont you have to drop the crank to do the rear main seal Sounds like a nightmare with the engine still in the car, if its even possible
No the rear main can be levered out and replaced with the engine inplace but off course the gearbox and flywheel out. The seal is pressed in with Litchfield Tool number E9312 or similar.
Edit: oops that's for the six not sure you can do it on the V8; in fact my V8 references say you can't do it without removing the crank.
Two SC 61's = trouble
Yep you can with out removing crank on efi Windors, but clevo's use the rope type in main, some have rear seals two piece..The old 250 sixes are a real pita to get to vertually have to pull whole engine apart...I have one XR6 that three attemps have been made to fix it last by me..Next step is a kit that goes over crank and better seal the F* cken thing won't leak next time !!!!
1 - 8 of 8 Posts
