Officially Bored with 347
Vent stuck on Fresh???????
Hey Fellas Im in need of some help....
My fresh/recirc lever thing doesnt seem to work.
I have pulled the control mostly from the dash & do know im getting Vacuum throught to it.
It just wont swap from fresh to recirc?? Upon closer inspection the lever is connected to a micro switch..
If i remove the pass side glove box & put my hand up the Airbox opening i can feel the blend door? it just swings from side to side & holding it either upwards or downwards doesnt seem to change anything (Fan Forcewise)
Can someone give me a clue here please...
Thankyou in advance...
Brett
345kw of V8 Windsor Power
Same thing happened twice in our EA. First time the mechanic said the solenoid behind the dash needed to be replaces and it was fairly common that it went. Second time I just found that a vac line under the car leading up to the ac was off. Reconnected that and it worked fine.
BA'o'Matic 100% working.
YES - the dash has to come out, or at least unbolted and pulled foward a fair way on the passengers side to remove it, I tried it without taking the dash it is IMPOSSIBLE :0)
TIKFD6 said:
I told you there was no easy way to fix it Brett.
But no dont listen to the 6 cylinder driver.
:p
LOL :wnc:
