I'm not kidding.
It started when I noticed the Head Gasket (replaced 1 yr ago) was leaking down the block when cold (between cyl 3-4 exhaust side).
Took the rocker off to check head bolt tension.
Inspected the timing chain & noticed half the chain guide on exhaust side had snapped off & was sitting in a valley near the chain.
I called my mate, (an ex ford dealership mechanic) when dismatled, the whole guide setup on both sides had disintergrated & was within a few k's of complete destruction, cam had slap, tensioner was all the way out.
The head leaks because the block came from the factory with a big ding on it between cyl 3-4 near a water jacket. Have to get it fixed, and the Ford VRS kit fitted by the dealer 1 yr ago, had a crap head gasket, fitting an Accel instead.
My sons ED had a similar tensioner guide prob but I thought it unique to him was because of getting a good flogging.
It seems to be a Ford design weakness.
All you 6 cyl owners out there - please CHECK YOUR
TENSIONER GUIDES !!
Take off the rocker cover and inspect before its too late.
- Frank
Yeah, these things are weak as P!$$.
Mine broke when the new cam was fitted.
I guess its a cheap bit of insurance, as the things are not expensive to replace, but if the thing does go, and bits of metal start to circulate around the motor :crazy1:
