Bronco Member
Hello all, i am the proud owner of a 90 Bronco. The rearend is conventional/ open. What was the option for the Bronco, Trac-lok? And was 30 spline standard? One other thing i am up in the air about is when i pulled the rear cover there was a "flywheel looking" gear on the outside of the ring gear? Something for anti lock breaks? Thanks for any help you may provide. If you know of any place to check out for a used trac-lok let me know. Regards.
RSH
Multi Ford Member
The tl axles for the 90 model was in 3:55 only. The 4:10 was not offered in tl.. You can change to a 4:10 tl as they are available. Also available is the 3:73tl.
Bronco Member
Discussion Starter · #4 ·
Thanks for the info guys. I finally got a chance to get a manual for the truck today. It's a "haynes" and definetly could be better but it will have to suffice for now. Regards
RSH
Bronco Member
the haynes manual i have briefly goes over stuff pertaining to the bronco. I picked up a chilton manual which seems to be a bit more detailed, but it still lacks info.
