Hi everyone, just wondering which unleaded fuel people are using in their pre unleaded engines. In my XA 302 I use premium with moreys valve lube.
Thanks Brian
Thanks Brian
How long has the 100 octane fuel been available for?superbird302 said:been running the new 100 octane optimax extreme in my coupe, seems to like it
I run BP Ultimate mostly but will try the new 100 octane shell when I find somwhere that has it.LUV DE COUPE said:Hi everyone, just wondering which unleaded fuel people are using in their pre unleaded engines. In my XA 302 I use premium with moreys valve lube.
Thanks Brian
probably a stupid question but what is the negative effects of ethanol. I was only looking at the octane rating for optimax extreme...does the ethanol damage your engine?xcgxl said:I use only 98 Ultimate. 100 Ultimate contains ethanol
I wouldn't use it in an old car. It can rot rubber seals, accelerate corrosion in the fuel system, lean off the engine, and produce greater evaporative emissions.superbird302 said:probably a stupid question but what is the negative effects of ethanol. I was only looking at the octane rating for optimax extreme...does the ethanol damage your engine?
I wouldn't use it in a new one either - I think we'll find it does most of that in them too. Just a matter of time.xbgs351 said:I wouldn't use it in an old car. It can rot rubber seals, accelerate corrosion in the fuel system, lean off the engine, and produce greater evaporative emissions.
I guess it depends if you keep or turn over your cars. I keep my old cars and turn over the new ones. I still don't run the BA on any fuel with ethanol, but if I did, it would be the next owners problem.northey said:I wouldn't use it in a new one either - I think we'll find it does most of that in them too. Just a matter of time.
Hi Brian ,LUV DE COUPE said:Hi everyone, just wondering which unleaded fuel people are using in their pre unleaded engines. In my XA 302 I use premium with moreys valve lube.
Thanks Brian
jg66me said:BP Ulti whatever!! Any of the 98 RON Pulps.
What I fail to understand, seeing as you cannot buy petrol with lead in it, why make any reference to lead at all? Is this some stupid politically correct marketing speak? Why not call unleaded "Regular" and PULP "Super".
Steve
Shell Optimax wasn't designed/produced with the intention of it being used in Carburettored Cars/Motorcycles/engines... was intended for fuel injected motors... (Read that somewhere ages ago when people were blowing Go-Cart motors on it Regularly)Jars said:I have had problems with Shell Optimax going off before, re: if vehicle (bike in this case) has been sitting for awhile (week or 2) was very hard to start from cold
