I have a 1994 f150 4x4 with a 302 automatic. the tranny in it i beleive is a E4OD but all i have is forward gears,even when it's in reverse and nuetral it still moves forward when you apply the gas. When it's in park and you press the gas pedal it wants to lurch forward but it's bogged down like it's stuck in a forward gear. i changed the gear position sensor/neutral switch module on the side on tranny thats on the shifter lever,but still does the same.....
SO my question is this... can i switch the E4OD out and put in a AOD? I know i wouldn't be able to use the push button overdrive. But do i have to switch computers from the one i have with the one that can out of the p/u with the AOD?
Or do you have any advice for me on what to or not to do with this project. thanks for taking the time to read this and for any help or advice you may give.
Thanks Again,
Poolgod27ia
Thanks Again,
Poolgod27ia
