Can some one tell me how the window washer jet are held in place, I have not as yet tried to remove the bonnet lining, any advice would be appreciated.
Numnuts.
known as tibbo
lift and twist.. the have a keyway they fit into.. you'll need to pop the lining not to get them out but to reattach the hose when u put them back in
ok thanks for that, just realised I forgot to mention it's a ghia ea '89, can you tell me how is lining held in, are the clips reusable or what.
numnuts
known as tibbo
yes .. now this is from memory so i might need a correction but the clips lift out with a screwdriver and can be just pushed back in.. You mightn't need to take the whole lining off if you can undo the two plastic screws nearest the windscreen and 'pop' the lining out of the channels at the back and shove your hand inside
