Hi, my name is Steve. Sorry to here that you have the same trouble I do. My van has 141,000 k and I have that same low engine knock or loose parts noise, less noticable at idle, but louder off idle. Also on start-up. Periodicly I get a rough idle, but no stall. I have also had the check engine light come on, and the fault code was PO171 system too lean( bank 1 ) I had just read a forum about the intake cover box gaskets, vacuum lines possibly to blame. Sorry I can't tell which forum (i just stummbled on it ) If you have some info about our common problem I would appreciate the heads-up Thank-you in advance. Steve
