I was lucky(or unlucky!!) and wiped all 16 lobes, so all i had to do was check one lifter. I pulled the rocker covers and pulled out a couple of lifters with a magnet and instantly found the problem, with no measuring. You can't do it this way with 4V heads.UCNTRY said:whats the easiest way to tell if you have wiped the lobes on a cam with out measuring lift at the valve or cam cam is a crow 211367 its hydraulic too
Ok sounds like you need a new fuel pump after you get the lifter problem sorted.UCNTRY said:the only thing i can find in my oil is petrol but when i started it up earlier on one of the lifters was really noisy
If its not a manual pump how did the fuel get into the oil? If the oil has been thinned out by fuel then you may already have damage thru loss of lubrication.UCNTRY said:it doesnt have a fuel pump on it it is electric pump and yeah its got a fuel rebuild 5000 ago and then had to redo heads and the cam looked warn at that stage so got the cam re profiled and new surfaces put on the lifters and also put stud mount roller rockers in at the same time
What did you find?UCNTRY said:that was the plan probably take manifold off tommorrow have a look at the cam and redo all the rockers and lean it off a bit think it might be runnin rich and seem to be havin problems with carb at moment think it might be flowing in while not running and running past the rings
Why not ?xdclevo said:I was lucky(or unlucky!!) and wiped all 16 lobes, so all i had to do was check one lifter. I pulled the rocker covers and pulled out a couple of lifters with a magnet and instantly found the problem, with no measuring. You can't do it this way with 4V heads.
There is a large gap cast into the 2V cast heads(AFD too) so getting a lifter out with the manifold on is easy. Bit harder getting back in. The 4V heads only have a small hole cast in, which is big enough for the pushrod, but not to retrieve a lifter through it.Rhett said:Why not ?
