I've just recently put an EA 'S' dash in my 1988 EA GL Falcon. I know i have to change the oil pressure switch to an oil pressure sensor as the gauge is pinned to the far right, but what i really want to know is, is there any way i can wire up the tacho without having to go from the pink/blue wire from the coil? Can i tap into the ecu to get the rpm readings and just run a wire from there? This would be much easier.
Also, how do you connect it into the lower connector on pin 8?
Information on this would be much appreciated.
