1 - 10 of 10 Posts
Yakuza Staff Car
Ok, i'm at my wits end with the ****ing car.. so here's the deal.. It's not sucking fuel from the tank.
It's got a BRAND NEW fuel pump, brand new filter, brand new rubber joints for fuel line connections, fuel tank PROFESSIONALLY cleaned out. YES it does have fuel in it. Also, the carbie (standard Stromberg) has had a new needle & seat installed and cleaned out.
I've also blown out the fuel line with compressed air, cranked the engine with no plugs in etc.. the fuel pump is primed, but that was from a fuel can.. not the tank
can ANYONE shed any light on my problem before i give up and send it to my mechanic...
cheers, matt :AAHHH:
Re: XC Falcon - 3.3l problems sucking fuel...XC Falcon - 3.3l problems sucking fuel...
Is the valve on the fuel cap clogged? If so, it may be causing a vacuum when fuel is sucked out, stopping the flow. Try removing the cap and starting it up.
Two SC 61's = trouble
I had this problem once in my 289 Escort...There was a rag in fuel tank...Even though it was cleaned out while still in car.Didn't notice till I took tank out...pita...hth
Bummer. Have to fault find bit by bit. Disconnect fuel line at pump and try blowing back down it - should hear bubbles in tank if not blocked. If OK, reconnect line. Then disconnect line at carb, crank it over (may take a bit to reprime pump!). Should have fuel if line and pump OK, if not, disconnect line at pump. Crank again - see fuel, pump OK. No fuel, pump stuffed.
If all this checks out, problem is at carb. The V8s often had a metal fuel filter at the inlet - yours may too. This may also be stuffed.
Good luck!
Check for air leak on suction line side of pump?? I take it the cam and pump arm are o/k?
BA'o'Matic 100% working.
If you pull the accelerator cable around does fuel actually pump in the carby or not, in the carby itself maybe the float has been set wrong and so is jammed and blocking fuel flow, or the needle is jammed in the seat ??
Jason
Yakuza Staff Car
Discussion Starter · #9 ·
the needle is free, and it'll run if i put fuel into the carbie, or run fuel from a fuel can... which is why i dont get it.. since the fuel line is clear and no blockages in the tank either...
ah well, cheers for trying to help.. it's going to the mechanic next week..
xd vans rock
have you checked the fuel pickup in tank it could be blocked
1 - 10 of 10 Posts
